1 - 7 of 7 Posts
So i got new tires about 3 weeks ago, idk if it has a connection to this, but about 2 days after i got them on, i heard a thumping or beating noise what seems to be coming from the front passenger side area. At first it only happened at around 45 mph or so. Now it seems to be off and on everytime i drive, any ideas?
Discussion Starter · #3 · (Edited)
Well it came loose but i bolted two parts back in, where exactly is it rubbing on yours the tire? Also i noticed on the top part how do you bolt thay up? Seems preety tight to get anything up there
Does it happen when you are going in a straight line or while turned in a particular direction?
Preety sure its mostly in straight lines, but i still get a little in turns depending on how sharp/ how fast im going around it
If it is not the shield, jack up the car and try shaking the wheel. There might be something loose under there.
Discussion Starter · #7 ·
Yea i did, didn't seem to find anything though, i think it is the shield, its just in a bad spot or something, i've already put two new bolts in, but from what i've seen the original bolts are preety flimsy, could be anywhere
1 - 7 of 7 Posts
