Are you replacing all the timing components, if not timing can be set with out dying all of that and just pulling the cam gear cover?
Grey rtv and just use a scraper and worse case a razor blade at a shallow angle.
Power steering pump needs to be unbolted and let hang.
You will need something to support the motor, cross brace from the top or jack with wood block(s) from bottom.
Did we not link you the FSMs? If you search you will find the link to the compete nissan manuals.
Alternator could have stayed on the motor, doesn't interfere with the timing cover, same with the water pump.
Pull the spark plugs too.
I find it easier to remove and install the timing cover from under the car.
