1 - 4 of 4 Posts
Replaced the head gasket like month and half ago, car delay in start so i suspected everything from cam position sensor and crank sensor and checked for vacuum leaks nothing, once the car starts it's perfectly fine, but this day i was driving around and it just died, and when starting it it shakes so much so I'm sure it's a vacuum leak, but again couldn't find anything, today i saw this part without hoses, should it have hoses? And if so where do i connect them?
172754
Year and model...I can't even make out what that is but its either there case someone installed it or some other thing that i can't think of cause if the is an 02-06 QR that's not stock.
A vacuum leak would eventually throw a code due to a lean condition if it was that bad. Whats your coolant level now?
Timing may not be set properly, I assume you did no relearns after replacing the head gasket either...
what angle was this picture taken from, top of engine? thats what it seems like if im seeing the cv boot correctly
1 - 4 of 4 Posts
