1 - 13 of 13 Posts
YOU USED AN IMPACT GUN TO TIGHTEN A BRAKE BANJO BOLT?!?!?!?!?!??!?!??!?!!!!?!?!?!?!?!?!
Face Outerwear Beard Tie Sleeve
It will come out, assuming you didnt damage the threads. Heat it up a lot, give it a little tappy tappy with a chisel, and then vice grip the material hanging out and out it comes.
Welding a nut should be last resort, that metal is going to be full of brake fluid, no matter how hot you get it, so the weld wont be the strongest. Really if you take that to a machine shop, they will charge you like $20 to take it out and check the threads.
Ok in my defense the location of the boot made it so I could only go 1-2 clicks with the torque wrench at a time in a really awkward position so I thought “hey I’ll just give it one or two clicks with the impact that outta speed this up”.
it seemed like a smart idea at the time. Maybe I’m just an idiot
And a brand new caliper is only $30-$40 depending on brand. Or I can go to the scrapyard and get one for $16 so no point getting it machined.
I was going to say a caliper is like 40$. Havent seen that before. Looks like the washer was reused a few times and over torqued to seal.
I've got both calipers rebuilt with a Nissan kit, painted high temp red, and have Goodridge SS brake lines that I will give you if you pay for shipping. I'll put up a picture when I get home. Shipping may be more than they are worth.
Facts
  • Haha
1 - 13 of 13 Posts
