Waiting on 2J ti retainers to show up....will get new cams and springs next month from JWT.
I'm going to part together a drivetrain to convert the B15 to AWD with the 6 speed transmission. Drag cartel has developed a front transfer case that works as a PTU (power transfer unit) for the K series and I'm exceptionally familiar with the AWD setup on the Ford Taurus, explorer, continental, etc (as I'm a senior master technician for Lincoln motor co.) I dont plan on the setup to be reliable just need to make the configuration cork correctly then will develop more to make the setup reliable. I'd like to acquire a front transfer case, rear subframe, rear differential, and another casing (cant remember the term) [fluid clutch casing between driveshaft and rear differential] to take measurements and continue development. Also having a Final drive ring gear from a 5sp MT from a x-trail would be helpful as well. Custom half-shafts and driveshaft would be a must. Don't really have any questions however lolWhat were you thinking in regards to X-trails ?
I can help with anything you might need to know.
One piece of information you might need to consider is the duty cycle capacity of the viscous coupling.I'm going to part together a drivetrain to convert the B15 to AWD with the 6 speed transmission.
I dont plan on the setup to be reliable just need to make the configuration cork correctly then will develop more to make the setup reliable. I'd like to acquire a front transfer case, rear subframe, rear differential, and viscous coupling to take measurements and continue development.
That I did number 6 lolHell yeah Mulholland that sounds pretty sweet. I remember someone doing an awd setup using an older Porsche rear end. Not sure what kind of trans or transfer case tho. It was all welded and bolted on, the the idea was ditched for no apparent reason. Id be excited to see it work. I would think alot of the truck stuff is way to heavy and bulky to be ideal, but for an awd B15 monster, id do it.
I just saw Kaz got another B15...
Currently there are mishi fans installed...but I also want to make sure there are no shorts and seeing if the likes have continuity.You can test the high speed fans by using a 150 Ohm resistor connected across the temp sensor plug after you disconnect it.
