What do you mean?Bearings love no center caps too
Dirt grime etc gets in amd wears them out quickerWhat do you mean?
I’ve had the rear bushing sitting in a drawer the past half year, I just got around to watching a video tutorial for the trailing arm bushings. Are the panhard and RSB bushings about the same difficulty and process?Recently installed super pro panhard, trailing arm bushings and RSB. What a world of difference, the ass just sits and does as its told through corners. Decided I'd pull the super pro bushings off of an old set of LCA's and retrofit the front, cant wait to have the front tightened up!
The trailing arms are cake its the pan hard thats a PITA. You will have to drop the entire beam axle to install the pan hard, there are no shortcuts here. But once its out and you have the later link and control rod in hand you can at least take them somewhere for the removal and install. I would HIGHLY recommend finding a shop to do this for you. If you are trying to do this as a home gamer and this is your daily driver, just remember, once you start burning out bushings you are committed. Set aside an entire saturday or sunday for this in case of unexpected snags.I’ve had the rear bushing sitting in a drawer the past half year, I just got around to watching a video tutorial for the trailing arm bushings. Are the panhard and RSB bushings about the same difficulty and process?
I just ordered 2JR’s lowering springs with the KYB struts so I may as well do a suspension refresh everywhere else when I get around to it.
Damn, I’m glad I asked now. I plan on doing all the work myself, and mine isn’t a daily driver so it’s not going to be a rush. I’m still not sure when I’m going to get around to this but now I know I should try to get a game plan before diving into it.The trailing arms are cake its the pan hard thats a PITA. You will have to drop the entire beam axle to install the pan hard, there are no shortcuts here. But once its out and you have the later link and control rod in hand you can at least take them somewhere for the removal and install. I would HIGHLY recommend finding a shop to do this for you. If you are trying to do this as a home gamer and this is your daily driver, just remember, once you start burning out bushings you are committed. Set aside an entire saturday or sunday for this in case of unexpected snags.
I didnt find much in the way of instructional video pertaining to the pan hard kit to know what I was up against and ended up mackivering a tool-less solution for the bushing installation. I broke out my gopro and got some footage of whats involved with the removal and installation. Ive yet to cut any video together but considering theres not much in the way of walk throughs your post has me motivated to cut something together finally.
Im happy to answer any questions you have. I'll link the video once I get around to cutting and uploading.
Definitly take the time to make a plan of attack, its not just the bushing installation that can be difficult. I kinda had to fight with re-installation of the beam axle. You are going to have to align two fixed bolts on the beam with the lateral link and control rod at the same time. I had my beam balanced on a floor jack, its going to want to cant over to one side as you try to make the holes align. Its definitely doable as a one man band but for the love of your fingers and appendages try to have some cribbing in place.Damn, I’m glad I asked now. I plan on doing all the work myself, and mine isn’t a daily driver so it’s not going to be a rush. I’m still not sure when I’m going to get around to this but now I know I should try to get a game plan before diving into it.
Yes, that’s the plan. I’ve got harbor freight’s ball bushing tool which looks to be perfect for at least the trailing arm bushings. I’ve also got a 17 year old brother to help me with the rear assembly so that shouldn’t be too much of an issue to remove or install that hopefully.Definitly take the time to make a plan of attack, its not just the bushing installation that can be difficult. I kinda had to fight with re-installation of the beam axle. You are going to have to align two fixed bolts on the beam with the lateral link and control rod at the same time. I had my beam balanced on a floor jack, its going to want to cant over to one side as you try to make the holes align. Its definitely doable as a one man band but for the love of your fingers and appendages try to have some cribbing in place.
You plan on doing the bushing installation at home as well?
Doing the bushes on our 2001 Corolla AE112R I used the same method with long bolts but different sized sockets to push and create a gap for the bush to pop out into.I essentially had to use long 10.9 bolts, large washers, and nuts to push bushings where I needed them with the harbor freight kit’s “cup” to create space for the bushing to go.
They all have two tap wields on the top of the rear strut bolts. I tried hitting it with a hammer and chisel for shits and giggles, but it didn’t do anything. I decided to just drill through it, and now I’ve got about a 10mm hole in the bolt head. I’ll just drop a new bolt in and call it a day.IIRC you can knock the stud out with a hammer, it's not welded in.
Yep, polyethylene for everything in the rear.I guess it would be easier off the car. Idk if those cylinders for the trailing arm would be available. Good luck on that, I see you removed them.
As far as fuel smell I do believe the vent valve is open when the car is off. Its probly just build up of fuel vapors over 15 years in the canister filter. Shouldnt be too strong if any tho. Replacing it wouldnt hurt.
Are you going poly bushings for the rear and qt link? Should be alittle easier to install than rubber.
