1 - 20 of 91 Posts
Hey guys as we all drive our B15's. Day by day I was wonder what you'll use and deside which is best for next change? I don't know if there's another post about this but sorry guys. :nervous:
I use Mobile 1 with wix filter.
BDSF
Mobil1 0w40, Bosch filter. Was using Castrol for a while, but it's hard to find 0w oil's without ordering online.
I have used both valvoline, and castrol full synthetics with a k&n filter.
castrol syntec or castrol edge 10w40 and k&n filter, sometimes mobile 1 filter if they dont have a k&n one in stock
IMHO the K&N oil filter is the better choice. The Nissan OEM filter is also very good because of its high flow characteristics. I would use Fram, AC, Autolite, Wix and other auto store filters in an emergency only.
5W-30 Castrol Full Synthetic and either Fram or K&N filters. Depends on which one they have in stock.
BDSF
Post up your oil weights. I'm surprised at how many people run 10+w oils, especially on a daily driven car :thinking:
Most synthetic oils are overpriced and overrated. Look into oils made by Shell (Rotella T and Rotella T6) and Mobil Delvac for diesel engines. They have as much if not more Zn than the top-rated synthetics at about half the price.
If I were living in Canada or North Dakota I would consider using 0+ oils in the winter. For my DD I use 5W30. On race day I switch to 10W40, 15W40, or even 5W50, depending on how hot it will be at the track.
Discussion Starter #14
Any one runs Royal purple? I have been wanting to try it just price out rages per bottle.:yuck:
BDSF
I don't think anyone lives in a climate where ambient temps would make a 0w too thin at startup. Someone who can datalog oil temp and pressure should do some testing, though.
I'm running a 10w right now (mistake) and IMO it is too thick for California weather.
The issue IMO is not whether it is too thick at start-up, but is it thick enough to protect an engine revving at 7,200 rpm.
Mobil1 high mileage and a Wix filter (or OEM Nissan if I remember to pick one up when I'm around a dealership). I'm running 5w30 right now but might switch to 0w30 in the winter. What's the difference between straight 30 weight and 0w30?
QFT. I used this when i was boosted and i swear the car ran better in every way. Smoother on startup, while idling and driving. I recommend this to every boosted spec.
Synthetic Mobil 1 and Mobil oil filter don't worry about getting a k and n oil filter Mobil is better and a little cheaper
1 - 20 of 91 Posts
