1 - 5 of 5 Posts
The paint on the window sills for my 05 Sentra has begun to fade and peel on all four doors.
I would like to remove them in order to clean, and apply coating on them, such as Dura-Cote.
Are they fastened inside the door, or do they pop off just being clipped on?
Also, I'll welcome any advise on coating the seals, tips on doing it, or what other products to use.
Thanks everyone!
Do you use a hammer and a screwdriver?????
or is there a special tool that can be used?????
I remember there being a post somewhere on here on how to remove them, you might have luck if you search. But I remember you have to pop off a sticker/cover that lets you remove a 10mm bolt. This accessed from the interior edge of the door (towards the top where it latches.) Then it pulls out.
1 - 5 of 5 Posts
