1 - 20 of 107 Posts
about 2 years in the making....
More pics:
car pics pictures by xvbrandonvx - Photobucket
Mod list (hasn't been kept up as well as I wish I would have)....
Engine
-Precision 5431 Billet 50 Trim Turbo
-Treadstone Turbo Manifold
-633 Injectors
-JWT Turbo Reflash with 7200rpm Rev Limiter and -2* Timing
-HKS Super AFR
-Treadstone 2.5" Intercooler Piping and TR8 Intercooler
-Greddy BOV
-Tial 38mm Wastegate
-Treadstone 2.5" Downpipe
-Stromung 3" Midpipe
-Stromung 3" Exhaust
-Walbro 255lph fuel pump
-RKB Engineering PVC Catch Can
-HKS Circle Earth ground system
-Hondata heatshield Intake Gasket
-SWA underdrive pulley
-JWT S1 cams
-JWT valve springs
-JWT balance Shaft removal
-NGK Colder Plugs
-Deadened Knock Sensor
-NX single fogger wet system (currently Uninstalled, would like to convert to intercooler sprayer)
-Treadstone Stainless Turbo Heat Shield
-Ported Throttle Body
-ES Motor Mount Inserts
-Koyo Racing Radiator
-210 Flex-a-Lite puller fans
-Optima red top battery
-2J Racing Vacuum Block
-Nismo oil filler cap
-Nismo radiator cap
-2J racing fluid caps
-Paint matched fuse box covers
-Carbon Fiber battery tie down
-Chromed radiator supports
Tranmission
-TWM Performance Short Shift linkage
-FIR Nylon Transmission Bushing set
-FIR Crossmember Inserts
Exterior
-Full Cobalt Blue color change (car was originally black)
-19x7.5" et44 Racing Hart GT-5
-225/35/19 Michelin pilot super sport 4s
-OEM Carbon Fiber Hood
-Composite Creations World Challenge carbon fiber lip kit
-VIS carbon fiber trunk lid
-custom STI style carbon fiber spoiler
-Carbon fiber fuel door
-Webasto sunroof
-Shaved Door Gaurds
-Shaved and Relocated Antenna
-35% Tint
-Rear Fenders rolled
Suspension
-Chromed and painted front strut tower bar
-Nismo Rear Sway Bar
-Tein Basic Coilovers
-Powerslot rotors
-Painted calipers
Interior
-Sparco Torino racing seats
-Sparco clubman 3-point harnesses
-Sparco Grip Pedals
-Re-upholster back seats in Sparco Red
-Re-upholster door inserts in Sparco Red
-Re-upholster Sparco Arm Rest
-Sparco Shift boot
-Microsuede Headliner with Spec V embossed in sunroof door
-Carbon Fiber Door sills
-Carbon Fiber Trunk Finisher Plate
-Painted trim
-TWM weighted billet shift knob
-Nismo switch cigarette lighters
-Nismo Floor mats
-Fiberglass gauge pods
-Raptor Performance Shift Light
-Autometer Phantom II Boost/Vacuum Gauge
-AEM Uego Wideband
-Faze Gauge gauges set in carbon fiber located in Glove Box (Volt, Oil Pressure, EGT, Fuel Pressure)
-Faze Gauge Morphers set in Carbon Fiber located in Lower DIN
-Indaglow reverse EL gauges
-Ractive Carbon Fiber Ebrake boot and handle.
Audio
-Alpine 7894 CD/MP3 Player
-JBL P650C 6.5 components
-JBL P652 6.5 coax
-JBL P1220 -12" subwoofer
-JBL P80.4 -4 channel amp
-JBL P600.1 -2 channel amp
-(2) Power Acoustik monitors PT-727MSV mounted in Sun Visors
-Xbox 360 mounted in Trunk with wireless controllers
-Monster Cable wiring
-Monster Cable distribution block
-Black and Decker 400 watt power inverter
-Wireless FM modulator
-Fiberglass/ lexan subwoofer enclosure
-Fiberglass rear deck lid
-Dynamat Extrmeme on door skins
Lighting
-Sylviana Silverstar Front Turn signals
-Sylviana Rear Blinkers
-Sylviana Rear Breaklights
-PIAA Ion Crystal Foglights
welcome nice whip way to rep the blue b15's
i love the interior how much did that set u back (front and back seats)
Dam ur spec is nice & clean keep up the good work:)
b14 ftw!!! nice cars man even the truck i wish i had a piece like that for the winter months...welcome
Discussion Starter #19
It sucks to fill a truck up with gas (about 14 MPG and a 17 gallon tank) however when you need it (snow like you said, or the 1st time you need to haul shit) you're glad it's in the driveway.
1 - 20 of 107 Posts
