41 - 60 of 64 Posts
while negotiating with Rick
for a set of street wheels
they would be perfect to test our tramlining theories
17x8.25, 25mm et iirc
i'd just remount the same street tires
and see if wheel width is the determining factor
i offered to swap the set of r888s for the set of xxr's
sound fair?
heavy wheels by the way
21lbs vs 18 for the 17x9 zegins
found these on their site
16x8.25
http://www.nlmotoring.com/XXR-527-Wheels-16x8-25-Matte-Bronze-p/52768087n.htm
perfect short track size
with 245/45/16 r888s
or Hoosier slicks
lanier raceplex track set^
@shanover maybe we could share ,
at least to try them out
lol
zegins and conti slicks for AMP
and now for the dragon
17x8.25 xxr's and ???
maybe some Korean dragon biters
http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Ecsta+V720&sidewall=Blackwall&partnum=44WR7V720&tab=Sizes
that's it
maybe 6 events for next year
got till april to get set
must stay off dragstrip
and run at 80% at track
60% at the dragon
max
:47:
sure, I'd be willing to share with you! and it would be interesting (even if you just tried the wheels and tires I have now) to see if it makes a difference in the tramlining. I have found out, over the last few days, just how bad traction suffers when the tires are cold. My all seasons MAY be All Summer Season tires. I guess the only really good thing, is they dont bounce and jerk all over the place when they break loose.
have a few preventive repairs to take care of over the holidays, and I am on vacation. (front wheel bearings, steering rack bushing, maybe a few other odds and ends)
Glad to see your house finally shaping up like you want it to!
edit to add: Still planning on going 5 lug, but have a long way to go to get there. I will order up all the parts, including wheels and tires, and do it all at once. I will have to get new hats for the front rotors as well. it will definitely be a project!
Discussion Starter #44
Nice.
I'm considering moving the battery to the trunk simply to free up space. It looks like it really opens up the engine bay in that corner.
The downpipe wrap looks significant/good/useful. I'm afraid I'm cooking my alternator with my unwrapped downpipe. I'm considering offset wrap rather than using the actual wrap.
I pushed my car back into the garage today. Trying to track down O2 wiring stuff, everything was unplugged when time ran out. I hope to get the car running with a working bank 2 heater element soon, and then hopefully pass emissions and get my car legal. For now its guts are open to the air.
Nice.
Discussion Starter #48
after two days of hard running
broke the spal fan mounts on one fan
replaced with jegs spring loaded mounts
oil had gone everywhere
traced to an unported valve cover
ported the VC
the mount on my boost control vibrated loose and was lost
boost controller now mounted on the valve cover
my fan controller t-stat had vibrated loose as well
giving the radiator giving intermittent fan operation
fixed with rtv
fans now work
runs and handles like new
after boost controller was reset
it idles smoothly and pulls from 2000 rpm up
this is the best it has EVER been
better than new
[except for cosmetics]
ported the VC
Hey man, can you explain this ported VC to me? Problem you saw and then what that means to port it?
Glad to hear it's running well. It's a rare but amazing feeling when they do, ha.
Discussion Starter #51
Discussion Starter #52
learnings
puting an 11 lb batery in the trunk does not in any way affect handling.
ether by feeling or what i can measure.
short fat, sticky, tires work well for turbo cars with cams
the conti slicks are 24" tall and 9.4" wide
and are imo, perfect with c1 cams
in the 0-130mph speed range
12kg springs with as little preload as practical,
are workable on the street for a sat nite special
and
provide added safety and car control, at higher speeds and Gs
SPAL fans are better
don't forget to drill out the valve cover
imo
Discussion Starter #53
Discussion Starter #58
fans finally failed this morning right after i mickey moused the fuel line hole
installed my old fuel pressure sender [from the nitrous kit]
in place of the chunk of hose with the hole
tried to cut out the fan block
but wires got so hot,
did not think that was a good idea
engine reached 224*f before i realized no fans
and then instant shut off
damn,da damn damn
damn,da damn damn
its always something
Discussion Starter #60
people have asked me multiple times what is your turbo kit and how much does it cost
it was done piecemeal,
i was very dubious of this project
and some parts i wanted cheaply replaceable
so here is the original version
2JR Full Race Turbo - 50 trim $ 7 99.00
TR Manifold, 2JR Downpipe $ 4 99.00
2JR Pro Race Oil Kit $ 1 99.00
2JR 900 CC Bosch Injectors $ 3 25.00
2JR Intercooler Kit with piping, couplers, clamps $ 5 25.00
2JR Heat Wrap, downpipe and turbo $ 9 9.00
2JR Oil Line Heat Wrap $ 4 9.00
2JR Downpipe, Mandrel Bent, with High Flow Cat $ 2 99.00
2JR Turbo Boost Gauge $ 1 29.00
Tial Full Race Wastegate $ 3 29.00
Tial Blow Off Valve $ 2 99.00
2JR Vacuum Block $ 59.00
a mechanical boost controller, turbo blanket, 340 fuel pump, 3" side exhaust and dual spal fans were added later
a stage 4 pressure plate and stage 6, 6 puck disk with steel 14lb flywheel were behind the motor
41 - 60 of 64 Posts
