Thanks for all the information. The medusa header looks intense and looked it up on their website, whats the difference between the medusa and a megan header with power? what changes? and for V2 cams is it just drop and go? without changing springs, lifter buckets and adjusting clearances? Turbo seems like a nightmare on a N/A engine without a good tune. Ive been reading about slapping a turbo on this platform but looks like problem after problem if Its not done right but we will see where this project takes me! its kind of a DD car I also have a Toyota Tacoma I use for work.
changing springs and using titanium retainers is recommended.
however ,i use the springs and oem retainers,
i don't go over 6800 rpm now
[if you keep the stock rev limit no new springs required, imo]
checking valve clearance is vital with any cam change
i only had to buy 2 new lifter buckets and that was with c1 cams, most radical then available
[head must be ground for lobe clearance, with c1s]
to turbo stock motor
the tune is vital on a stock motor, flash tune
even before startup
then retune on the dyno
for turbo
this is a must
imo
by now it has been done 100s of times safely on qr25de's
limited boost, well tuned
personal opinion now
i don't trust turbos for DD drivers
that said
check shanovers build
more rad than mine
and used daily
