patric:
i'm not saying that the code can't be removed by changing the bottom o2. i don't need to see the video, and i believe that your code went away.
Regardless, i was in the same position that the OP was in, and even replacing the bottom o2 did not help. so, i went against what the code said, AND what nissan said, and replaced my top o2. problem solved.
i'm not discrediting you or anyone else, but honestly, i had the same problem as this guy for a year and i told him how i fixed it. if you want to argue that fact, go for it. i can't prove or disprove it worked, but i can tell you it most certainly went away after i changed the primary o2. now, i'm no electrical tech, but it's hard to refute something that works. i looked for months and months and kept reading the problem was the bottom o2, yet every time i replaced mine (or others did theirs) the codes stayed. it's not a coincidence, it was just the wrong thing that needed replaced. take it how you want, with a grain of salt or a shot of vodka, it worked. i'd almost bet money that it would work for him, too.
just for checkings sake, have you checked the wiring running to the bottom o2 AND the top o2? as patric said, it could be a frayed wire somewhere and 0037 is for a bottom o2 (this is a fact, i have the code right now because my bottom o2 isn't even connected), but i'm still willing to bet that it's the primary o2, seeing as he's replaced the bottom o2 before to no avail.
anyway, i hope he gets his shit fixed regardless of what it is. i don't enjoy sentra forums because this shit always turns into a fucking pissing match.
i don't come on here to argue or bitch. if i wanted to do that, i'd sign up over at hondatech.
