21 - 40 of 192 Posts
I have sum wd40 if you need help to open it up:cool:
yea the blue led flashes when i push the clutch and the gas down i went tru all the steps. i tried both just the box and with the cable ill try going under the advance setting now. i did noticed on here yall say take the red toward the coil and the black towards the ecu. but on there site it say take the black towards the coil and the red towards the ecu. ill try swapping that but i doubt that will fix it.
I'm pretty sure it was set for 6 cylinder, IDK if you changed it. (not trying to be remedial, just trouble shooting)
Mine is set up to read RPM off of an injector signal because it wouldn't read off of a coil.
mine sut up on injector signal and its set up on four cylinder
so exactly wtf is this for? never seen it lol
Edit: NVM already searched...pretty cool =)
i tried switching the wires on the coil that made the car run like some shit, so i dont know if just the box is bad or what i have checked and triple check everything seems like its fine but i dont know
let me pull up the interface and see if I can remember how to make it work....
REMEMBER this was a prototype box, so it's nothing like a current version.
yea i have my clutch set on inverted, here is a pic of it not real clear took it on camera phone.
thanks alot
if you do a read with the car off, in gear, key on, gas pressed, will it pick up throttle? Can you do it with the clutch in too so I can see if the voltages change?
here it is the voltage did change when i pressed them down.
yea it show rpm even if i rev it up and hit read i can read the higher rpms
